deleting the first element of a list
  • May 28, 2020 2:51 PM UTC
  • 305 views
Hello!
I'm new to FME and I'm getting stupid about a simple task:
I want to take the second element of list I created and write it into a new attribute (X2), which doesn't work.
If I begin by grabbing the first element like this, it works:
import fmeobjects
class FeatureProcessor(object):
def input(self, feature):
feature.setAttribute("X2",feature.getAttribute('List{0}.X'))
self.pyoutput(feature)
However, If I change that code to start grabbing values by the second row (change the code to "feature.getAttribute('List{1}.X')", I get an empty output.
Can anyone help with this? Or is there any other solution that fits? Basically, I have an X-Coordinate-Attribute and I want that X-Coordinate to be substracted with the following X-Coordinate in the same attribute. I thought deleting the first element and then merging the resulting attribute to the original attribute would be the easiest solution.
Thank you!
Forum|alt.badge.img+54
  • May 28, 2020 3:02 PM UTC
Is there a reason for using python?
If you want to get the second element of a list as an attribute you can do this, or use a listindexer to do the same
  • May 28, 2020 3:14 PM UTC
I agree with @ebygomm, try to keep it simple whenever possible.
Also, are you 100% sure that the list has more than 1 element when it arrives to the PythonCaller? Try setting a breakpoint before the PythonCaller and inspect the list elements.
mark2atsafe
Forum|alt.badge.img+59
As to the Python code, I've tried this and it does seem to work fine for me.
I do echo the other comments here though:
  • Is there a reason you need to use Python? It's generally easier to use a transformer
  • Does your list always have an entry for {1}? You can check in the Inspector, even on the PythonCaller output
One other thought - which is perhaps more a question for the Python community - is there a reason to use a Class rather than a Function? I understood Functions are for processing single features, which you are doing here.
In fact, that makes me wonder if you are possibly misunderstanding the nature of a list, which is a set of attribute values on a single feature, not a sequence of features.
i.e. if you want to replace the X value of one record with the X value of the next, then try Adjacent Feature Attributes in the AttributeManager (we can help with that if it's the case).
In general we don't have a list element deleter/remover. What I've done in the past is add a Counter transformer before I create the list so that I also have list{x}.ID. If I want to ignore the first record I set list{0}.ID to 9999 and then use a ListSorter on ID, so that the top element is now at the bottom.
It's not the same as deleting, but it often does what I need.
I hope something here is of use.
