Data Extract from Website
  • Sep 12, 2022 1:16 PM UTC
  • 91 views
nielsgerrits
Forum|alt.badge.img+67
Use the "Esri ArcGIS Server Feature Service" FeatureReader or Reader.
Put
https://idpgis.ncep.noaa.gov/arcgis/rest/services/NWS_Forecasts_Guidance_Warnings/NHC_tropical_weather_summary/MapServer
in the dataset field and choose the layers under Feature Types To Read (FeatureReader) or Parameters (Reader).
danilo_fme
Forum|alt.badge.img+58
  • Sep 12, 2022 1:37 PM UTC
Hi @asadamjad​
You can get to these features using the Esri ArcGIS Server Feature Service reader but you have to update the URL just a little:
https://idpgis.ncep.noaa.gov/arcgis/rest/services/NWS_Forecasts_Guidance_Warnings/NHC_tropical_weather_summary/MapServer/
After you select the layer that you want to explore:
Layer
Attached the Workspace. Please - check if is the layer that you want to explore.
Thanks in Advance,
Danilo
