CUT and FILL with arcpy in FME
  • Jan 3, 2021 6:36 AM UTC
  • 0 replies
  • 84 views
venu
Forum|alt.badge.img+5
I want to calculate CUT and FILL volume between"Existing DEM raster" and "Planned DEM raster" using Arcpy CUT and Fill geoprocessing tool script in FME Pythoncaller Transformer (FME DESKTOP 2017.1.2.0).But I am getting below error
Python Exception <ExecuteError>: Failed to execute. Parameters are not valid.
ERROR 000865: Input before raster surface: elevation01 does not exist.
ERROR 000865: Input after raster surface: elevation02 does not exist.
Failed to execute (CutFill).
Error executing string `import fme
import fmeobjects
import arcpy
def processFeature(feature):
dataset = feature.getAttribute('_dataset')
arcpy.env.workspace = dataset
# Set local variables
inBeforeRaster = "elevation01"
inAfterRaster = "elevation02"
outRaster = "D:/CutFill"
zFactor = 0.5
# Check out the ArcGIS 3D Analyst extension license
arcpy.CheckOutExtension("3D")
# Execute CutFill
arcpy.CutFill_3d(inBeforeRaster, inAfterRaster, outRaster, zFactor)'
Factory proxy not initialized
f_76(PythonFactory): PythonFactory failed to process feature
Clipper_Raster(RasterClippingFactory): A fatal error has occurred. Check the logfile above for details.
Kindly guide to me to find the issue in above script .
Thanks
Venu
