Curves error from the dissolver
  • Sep 15, 2020 8:01 AM UTC
  • 77 views
bubblebeb
I am using the dissolver to aggregate and dissolve area polygons grouping them by an ID.
I am getting the error below but when I test the incoming geometry it is all areas.
2020-09-13 14:27:09|20366.8| 54.1|FATAL |Expression: !isPoly || curve->isClosed2D()
Any ideas how this can be resolved?
Thanks
jonas_nelson
Forum|alt.badge.img+34
  • Sep 15, 2020 11:27 AM UTC
Just a hunch, but I guess that error message might mean that there is some geometrical/topological errors? Maybe polygons that are not closed (even though you said you checked - what did you use to test that?), or duplicate points, self-intersecting polygons etc.
Maybe you could check them with a GeometryValidator first, and repair them?
DanAtSafe
Forum|alt.badge.img+23
  • Oct 7, 2020 6:36 PM UTC
Hi @bubblebeb​ This looks like a problem with FME. Please submit a case if you can reproduce the problem in the latest release or betas.
bubblebeb
  • Oct 8, 2020 7:11 AM UTC
Thanks @danatsafe​ I have submitted a case for it.
