CSS Selector
  • Aug 10, 2023 8:01 AM UTC
  • 68 views
checcosisani
Forum|alt.badge.img+14
Hi
which is the correct css to extratc only the first div
this not work
#tabella > tbody > tr:nth-child(-n+30) > td.text-left > div:first-child
thx
Francesco
Forum|alt.badge.img+54
  • Aug 10, 2023 10:44 AM UTC
Are you looking to extract the first word from that column in each row of the table, i.e. excluding the part in italics and the part in bold?
checcosisani
  • Aug 10, 2023 12:12 PM UTC
Yes
  • Aug 10, 2023 12:55 PM UTC
Yes
I don't think  you can do that through css selector alone. You should be able to select the entire text with .DataText2 and then use some regex in a stringsearcher to grab just the first portion of text
[\w\s\d]+
checcosisani
  • Aug 13, 2023 8:25 PM UTC
[\w\s\d]+
Ok
also in this case isn't possible to extract the part after span ?
article:nth-child(-n+30) > div > div:nth-child(3)> div > p:nth-child(3) > span
thx
Francesco
