Creating Polygons / Spline lines from Points
  • Nov 10, 2023 7:06 PM UTC
  • 221 views
galigis
Forum|alt.badge.img+22
Hi All,
I'm working on a workbench to create smooth arc/ polygons from N, S, E, W and NW readings. I was able to calculate the lines & point based on the readings but need help to draw the spline lines/polygons in FME.
Below an example of the point and lines extracted from N, S, E, W and NW readings:
Points...and the following screenshot shows the desired output: spline lines made the polygon
PolyI'm wondering if there's any way to create those splines to make the final polygon?
Thanks 🙂
  • Nov 10, 2023 10:55 PM UTC
Hi @galigis​ ,
I don't think there is a transfromer which generates spline curves, but Generalizer transforms hull of the input lines to a smooth polygon close to your image.
  • HullAccumlator
  • Generalize with Algorithm: NURBfit (Smooth)
smooth_polygon
galigis
  • Nov 11, 2023 12:05 AM UTC
Thanks @Takashi Iijima​ we both reached to the same conclusion 🙂 thanks again
