Creating a bounding polygon around Esri Asc Grid (excluding NO DATA)
  • Mar 31, 2021 4:28 PM UTC
  • 119 views
chrbalm
Forum|alt.badge.img+8
I am looking to see if I can create a bounding box around an Esri Ascii Grid, but only around the points that have data (i.e. excluding any NO DATA values).
I am aware I can use a Hull Replacer to create a bounding box around a dataset, but the main barrier is how to query the grid file itself and remove NO DATA values.
I have tried to open the asc file in Notepad++, but it's huge and is unreadable due to it's size.
Any suggestions would be appreciated.
Cheers.
  • Apr 1, 2021 7:14 AM UTC
One possible way:
  1. RasterCellCoercer to convert raster to points
  2. Tester to exclude NODATA
  3. HullReplacer
It may be slow if you have a huge amount of data, however.
  • Apr 4, 2021 5:34 AM UTC
Hi @cbalmbra1​ ,
The RasterExtentsCoercer (Extents Type: Data MBR Extents) might help you.
