Create simple batch file and run
rakeshreddy0996
I have one input and only one output like below
there doesn't have any complication to run but i have nearly 1k+ repeated tasks.
https://i.stack.imgur.com/vehJK.png
jkr_wrk
Forum|alt.badge.img+29
  • July 7, 2021
What is your question?
You can run FME from a batch file.
On the second line of your workbench log file (after running) is the command-line that you need.
rakeshreddy0996
Thanks jkr_da.
How to create batch file.
i tried with batch deploy but in that only getting WB path so i need to create batch with parameters.
jkr_wrk
  • July 7, 2021
rakeshreddy0996 wrote:
Thanks jkr_da.
I think you are looking for another solution.
So if you give more information on what you really want to achief we could help you solve the work easily.
I think that you could do something with the following settup:
Creator -> FeatureReader (Format: Directory and File Pathnames) -> WorkspaceRunner
Or
Creator -> FeatureReader (Format: Directory and File Pathnames) -> FeatureReader (Format: OGC GeoPackage) -> FeatureWriter (Format: Esri Geodatabase (File Geodb))
I guess you want to scan multiple folders that contain *.gpkg files and want to convert every file to a *.gdb in the same folder with the same name?
rakeshreddy0996
Thanks jkr_da.
I have only two steps in one WB but need to run 1000+ files so i need to give parameters at a time and then i'll check final data of 1k data directly.
gazza
  • July 8, 2021
Although possible it's not often you need to use batch files with FME. Usually if you are processing lots of files you can just select them all with the reader and if they each need to go into separate output files you use a fanout on the writer and just process them all in one run.
If the workspace is more complicated and can only process on file at a time then use a master workspace with a WorkspaceRunner transformer to run the processing on each file at a time.
jkr_wrk
  • July 8, 2021
Thanks jkr_da.
See my attached workspace:
