Create DEM from the elevation points
  • Jul 26, 2021 10:13 AM UTC
  • 6 replies
  • 415 views
jugoslaviaa
I have a 2D point dataset with elevation information. They are not evenly distributed on the field. However, I would like to create a DEM based on the information I have. Which steps should I follow?
My final goal is to calculate the Surface Volume. Therefore I need to generate a DEM.
Thanks in advance.
Best answer by caracadrian
I would like to calculate the volume using the raster DEM. I have a base level from where the height will be calculating @caracadrian​
You need to prepare your data for VolumeCalculator.
I recommend creating upper and lower surfaces, clipping them to the same footprint and using SolidBuilder to create a solid that FME can calculate volume on. You have to be careful on how you handle voids.
itsmatt
Forum|alt.badge.img+48
  • Jul 26, 2021 11:11 AM UTC
FME has a couple of options for this (DEM creation).
If you need a Raster DEM (e.g., GeoTIFF or ascii grid) then there is a tool called RasterDEMCreator, this lets you choose a tolerance and a output pixel size.
Alternatively if you want a triangulated mesh you can use the SurfaceModeller, this will output a TIN.
Alternatively if you just want regular points then you can use the DEMGenerator to get a grid of points to your desired resolution.
All option allow for the inclusion of breaklines if you have them.
caracadrian
Forum|alt.badge.img+23
  • Jul 26, 2021 11:43 AM UTC
Use 3DForcer to set Elevation to your elevation attribute values.
Input your 3d points to the Points/Lines port of DEMGenerator or SurfaceModeller, chose the Surface Tolerance, Interpolation Method and Cell Spacing.
Do what you need to do with your DEM.
jugoslaviaa
  • Jul 26, 2021 2:13 PM UTC
jugoslaviaa
  • Jul 26, 2021 2:18 PM UTC
@caracadrian​ as you recommend it, I used 3DForcer  to set the elevation. Then I wanted to use DEMGenerator  however what should Breaklines be?
caracadrian
  • Jul 27, 2021 4:33 AM UTC
Breaklines are 3D lines that indicate a forced change of slope. For example the toe of a roadway or river edges.
They are very important when your points are not distributed evenly or to increase accuracy of your surface model.
caracadrian
  • Jul 27, 2021 4:44 AM UTC
