Create bottom edges of the solid geometry classes
  • Mar 11, 2022 3:57 PM UTC
  • 80 views
quangu
Hi FME:ers!
My task is to find a way to create polygons at the bottom of each solid geometry classes. The created polygons should follow the solid geometry classes bottom edges (x, y and z). I have marked a dark line in the picture for more understanding.
  • Mar 13, 2022 2:24 PM UTC
Hi @quangu​ , I found that each object is an aggregate of a lot of voxel boundaries.
If I understand your requirement and data structure correctly, the workflow shown in the screenshot extracts "bottom" surfaces for each class.
Deaggregtor: Decompose the objects into individual voxel surfaces.
Matcher: Filter out internal surfaces, which are duplicated.
PlanarityFilter: Calculate the normal vector for each surface.
Tester: Select "bottom" surfaces, whose z-component of normal vector is equal to -1 (i.e. downward).extract-bottom-surfaces
quangu
  • Mar 14, 2022 7:27 AM UTC
Thank you so much takashi, this is what im looking for!
