Create a new record
  • Sep 13, 2022 1:52 PM UTC
  • 162 views
Forum|alt.badge.img+3
I have a tester that checks if the user entered something into a user parameter. If they don't enter something then I want to create a new record. Currently it tests for the null and then it essentially stops as no data comes through. I want to create the data thorough a series of calculations. How do I do that?
Best answer by ebygomm
What is going into the requestor?
Just a feature created in a Creator (I've updated the screenshot)
Forum|alt.badge.img+54
  • Sep 13, 2022 2:07 PM UTC
You could use this sort of workflow, a feature will only exit the unmerged requestor port if the parameter tested for in the tester is not completed
  • Sep 13, 2022 2:15 PM UTC
  • Sep 13, 2022 2:17 PM UTC
  • Sep 13, 2022 2:35 PM UTC
Thank you! That worked perfectly!!
