could i put the output of FME from reading pdf file as image in one sheet of excel file
  • Feb 4, 2021 7:55 AM UTC
  • 92 views
spiderman
Forum|alt.badge.img+7
How could i put the output of fme as image in sheet of excel file ?
i have read Pdf file and after i worked on it at Workbench and did some modifications .i would like to have the output inside sheet in excel file as image.
How could i do that ?
FME version 2018
Thanks in advance .
@spiderman​ This webinar has some ideas on adding images to Excel and this Tutorial
spiderman
  • Feb 4, 2021 8:52 PM UTC
thanks for reply ,but i have looked to the tutorial ,it adds image from map url but not from pdf , i am little bit confused how could i insert image from pdf to excel sheet .
