Could I get road map Geometry from Google maps to enter as input data in FME
gogopotter90
Forum|alt.badge.img+13
i Would like to have the road map geometry as input from Google maps or any other app.
and use it as input data to FME to define which cable located at this road and so on .
FME 2021
Best answer by danminneyatsaf
gogopotter90 wrote:
Thanks to know , is there other source that I can get road data as lines with attribute name of the road ?
Hi @gogopotter90​, you could try using OpenStreetMap, which is an open source community built dataset that contains road data in it.
Alternatively, local universities and city open data portals are also great resources for geospatial datasets (and usually road datasets).
f.kemminje
Forum|alt.badge.img+11
  • October 31, 2022
You should first use Google Earth to create a kml file. You won't get vector lines from Google map as input.
Forum|alt.badge.img+50
There's no way to get the road data that Google uses into FME.
gogopotter90
  • October 31, 2022
thanks for reply ,but which data should I will get in kml file if I do not get lines vector
gogopotter90
  • October 31, 2022
danminneyatsaf
Forum|alt.badge.img+12
  • November 1, 2022
