Copy cell value to another in the same column with condition
  • Jul 24, 2023 10:08 AM UTC
  • 142 views
user01
Hello,
I think the answer is easy but I don't know how to do.
For each fme_basename value, I want to copy the B3 cell value to the B1 cell.
Thank you !
danilo_fme
Forum|alt.badge.img+58
  • Jul 24, 2023 2:44 PM UTC
Hi @user01​
I used the transformer AttributeManager to it this action.
If you enter the transformer you can see that the option Enable Adjacent Feature Attributes was enable:
Adjacent
Result in FME Data Inspector:
ResultValue
Attachd the Workspace template.
Thanks in Advance,
Danilo
user01
  • Jul 25, 2023 6:16 AM UTC
Hi @user01​
Adjacent
ResultValue
Thanks in Advance,
Danilo
Thank you for your answer ! I have a 2019 FME version so I can't load the AttributeManager, can you save the workspace in an older version please ? Thank you.
hkingsbury
Forum|alt.badge.img+73
  • Jul 26, 2023 8:27 PM UTC
you can't save a workbench as an older version, core fme components in newer versions will not exist in older versions.
What version of 2019 do you have? I had a look in 2019.2.3 and the attribute manager has adjacent feature handling - In fact, i think its been around since at least 2017... (might be wrong on that tho)image
user01
  • Jul 27, 2023 6:34 AM UTC
Yes I see it ! I try end tell you. Thank you !
