Converting numbers to geometry
  • Jun 4, 2021 3:52 PM UTC
  • 96 views
larue
Forum|alt.badge.img+12
I have a data set with numbers in x y z sequence separated by "," representing 3D geometry polygons and points. It was originally WKT and had been formatted to work with Dynamo (Revit).
Here is a sample of a point:
841.99951171875 678.6250000000001 -132
Here is a sample of a polygon:
409.000000000001 473.499999999999 372,409.000000000001 797 372,487 797 372,487 871 372,1275 871 372,1275 476.286679607417 372,1275 461.500000000111 372,409.000000000001 461.5 372,409.000000000001 473.499999999999 372
My hunch is to chop everything up into x y z attributes and then reconstitute into points/polygons. Using two AttributeSplitters, I can create a list, but then, how do you assign these numbers to x y z in sequence? It is so close to WKT, maybe there is an easier way?
Thanks,
@larue​
Best answer by debbiatsafe
Hi @larue​
You could try using an AttributeCreator or AttributeManager to format your data as WKT and then use a GeometryReplacer.
For example, with the point data, insert POINT ( in front of the data and ) after to create
POINT (841.99951171875 678.6250000000001 -132)
This value can then be used in the GeometryReplacer with the geometry encoding as OGC Well Known Text.
debbiatsafe
Forum|alt.badge.img+24
  • Jun 5, 2021 12:14 AM UTC
Hi @larue​
danilo_fme
Forum|alt.badge.img+58
  • Jun 5, 2021 7:16 PM UTC
Hi @larue​
Nice job @debbiatsafe​
