Converting FME 2014 SP1 workbenches to 2016?
  • Jan 22, 2016 8:22 PM UTC
  • 29 views
dfresh
I have about 15 FME 2014 scripts, that I want to convert to 2016, obviously this is a huge jump, any obvious examples for making this update much easier?
thanks,
Best answer by erik_jan
You should not need to convert your workspaces.
Workspaces created with FME 2014 are supposed to work using FME 2016.
If needed, FME 2016 has the option to update transformers, but if your workspace does not need any new functionality you can run them using FME 2016 without updating.
erik_jan
Forum|alt.badge.img+26
  • Jan 22, 2016 8:32 PM UTC
