Convert linestring text to line geometry
  • October 29, 2020
  • 267 views
Greetings, I'm pulling from a datasource that has a column of linestrings (example below) and i just need to convert this to line geometry in order to derive a polyline shapefile. which transformer(s) can i use? Thanks
"Geometry": "LINESTRING (-107.726325 39.50062, -107.72632501 39.50062042, -107.72632492 39.50062061, -107.72632458 39.50062097, -107.72632481 39.50062182, -107.72632666 39.50062407)",
Best answer by ebygomm
This looks like WKT
If you can isolate this part  you can use it in the GeometryReplacer to rebuild the line
Forum|alt.badge.img+39
  • October 29, 2020
This looks like WKT
  • October 29, 2020
ebygomm wrote:
This looks like WKT
Thank you, that worked
