Connection to SharePointOnlineConnector
  • Oct 28, 2022 1:19 PM UTC
  • 94 views
nielsgerrits
Forum|alt.badge.img+67
A while ago I followed the article How to create a Sharepoint Web Connection and successfully created a web connection using the "Connecting to Sharepoint with your own Client ID [Multitenant]" steps.
Now a coworker needs to use SharePoint in FME as well, so I exported the Web Service from my machine, imported it in the other machine and created a Web Connection based on this.
Creating a web connection with the other user fails, after the username is entered. The error message is:
Administrator approval required
unauthenticated
needs access to resources in your organization.
This access can only be made by an administrator. You must ask an administrator to grant this app permission before you can use the app.
Do you have an administrator account? Sign in with that account
When I use my login, it just works. So the Web Service seems to be fine.
Did I forget a step? Or did IT tighten the app aproval process in the meantime?
f.kemminje
Forum|alt.badge.img+11
  • Nov 2, 2022 6:27 AM UTC
May be access issue in your office network.
As error msg says
nielsgerrits
As error msg says
I'm afraid you are right :( this is no bueno as getting things done by IT is... challenging.
