Connection to AWS RDS Postgres using Forward Proxy on FME Server
  • Oct 25, 2022 10:46 PM UTC
  • 44 views
pwilkebrown
Forum|alt.badge.img+8
I can create an AWS RDS Postgres Reader and Writer on FME Desktop and successfully run the workspace. However after publishing the workspace FME Server it fails. It looks like Readers/Writers to AWS RDS Postgres are not using system Proxy Settings. Completed steps in manually setting the proxy:port using fme.exe in the FME Documentation.
Thanks
sanaeatsafe
Forum|alt.badge.img+9
Hi @pwilkebrown​ ,
To confirm, did you follow the steps to configure the system proxy found in the FME Server documentation? These settings can be managed from the FME Server Web UI > Admin > System Configuration > Network & Email > Proxy.
Does the job produce an error message when it fails? If so, please share it or the job log.
We also have a reference guide for Troubleshooting Proxies in FME Server that may list similar symptoms to your issue.
Thanks,
Sanae
