Clipping lines on DEM
  • Dec 6, 2020 12:23 PM UTC
  • 40 views
cdalessandro
Forum|alt.badge.img+4
I would like to use DEM to clip lines. Despice it seems simple, I still haven't gotten it. Any suggestions? Please see attached fmw and readers zip file.dem_clip
hkingsbury
Forum|alt.badge.img+73
  • Dec 6, 2020 6:46 PM UTC
Pass the dem through a HullReplacer. Then use the hull to clip the lines
cdalessandro
  • Dec 7, 2020 2:44 PM UTC
Thank you hkingsbury for suggestion.
I tried to use HullReplacer transformer. It worked on thin surface only (no DEM). This is fine but, as you can see in picture, it seem drawing lines from index 0 point of DEM boundaries to each point of the area itself. I tryed every settings of HullReplacer transformer. Do you have an idea this behavior why? How can I to drape exactly DEM profile? If you want to try, you can use attacched zip file with readers.
Thank you
Corrado
HullRepalcer
