Changing specified value with an attribute
  • Nov 29, 2023 10:17 AM UTC
  • 8 replies
  • 2005 views
scarter
Forum|alt.badge.img+10
Hello Forum,
I've searched previous questions, but couldn’t find an answer. I've no doubt someone has posted this before. But, sorry, I couldn’t see it.
I need to replace a specified value within an attribute to another value. I have an attribute (field) called Zone Type. Each cell in that attribute has one of several possible values. Where the value is "container" I need to replace it with "Outside CPZ". I don’t want to change any other values.
How do I do this? I've tried through AttributeManager but couldn’t work it out.
Thanks,
Stuart
  • Nov 29, 2023 10:31 AM UTC
scarter
  • Nov 29, 2023 11:00 AM UTC
Thanks for that, takashi
I’ve added a AttributeCreator before the AttributeManager.
I’ve chosen zoneType as the Output Attribute.
In Conditional Value Definition I have Left Value as Container. I have the Operator as =. In the Value box I have Outside CPZ.
But when I run this, the cells that were Container are still Container.
Thanks,
  • Nov 29, 2023 11:16 AM UTC
Thanks,
The Conditional Value Definition should look likd this, if I understand your requirement correctly.
fig-2If the value of "Zone Type" attribute is "container", then assign "Outside CPZ" to "Zone Type", do nothing otherwise.
fig-1
scarter
  • Nov 29, 2023 11:39 AM UTC
Thanks,
Hi. In your image your have a Test field and a Value field. But in my Conditional Value Definition I have these fields...
  • Logic
  • Left Value
  • Operator
  • Right Value
I have set left value to @Value(zoneType) =Container and Right Value to Outside CPZ.
I don't think I have got this right.
  • Nov 29, 2023 11:55 AM UTC
Thanks,
Conditional Value definition has a few steps. Hope this screenshot helps.
fig-3
scarter
  • Nov 29, 2023 12:09 PM UTC
Thanks,
Hi.
I cant get it to work set up like that.
You've been very helpful, thank you. But I don't want to take up any more of your time. I'll raise a case with Support.
Thanks,
Forum|alt.badge.img+63
Thanks,
Can you post a screenshot of what it looks like on your end?
scarter
  • Nov 29, 2023 3:27 PM UTC
Thanks,
Thanks for that. It's all resolved now.
thanks,
