Cannot get PythonCreator script to expose attribute.
  • Nov 1, 2020 10:46 PM UTC
  • 110 views
amc
Forum|alt.badge.img+3
Hi there,
I am running below script succesfully in the PYTHON Creator but i can't get it to expose a created value into and attrribute. the script creates a 3 digit number in ICP_GEN_ICP based on a parameter I provide for CheckICP, but it won't get exposed. i need to know how I can assign this value to an attribute and use it in an XML templater. thanks!
ps i am new to coding ( both FME and Python)
script:
D = int('0x180f', 0)
H100 = int('0x100', 0)
H1000 = int('0x1000', 0)
HFFFF = int('0xffff', 0)
def Asc(bytes_obj):
  '''Get the int value of a char'''
  if type(bytes_obj) == bytes:
    return bytes_obj[0]
  else:
    return ord(bytes_obj[0])
def Mid(string, integer, integer2):
  '''Select a substring from a string'''
  integer = integer - 1
  return string[integer : integer+integer2]
def gen_crc(icp_number):
  """ Generate a checksum for an ICP"""
  R = int('0', 0)
  CheckICP = FME_MacroValues['icp_number']
  ICP_GEN_CRC = ""
  IChar = 0
  if len(CheckICP.strip()) < 12:
    ICP_GEN_CRC = "Insufficient Data"
  else:
    CheckICP = CheckICP[:12] + "\\0\\0\\0"
    #print('CheckICP: ' + str(CheckICP))
    for I in range(0,108):
      #print(I)
      if I%8 == 0:
        IChar = Asc(Mid(CheckICP, int((I/8)+1), 1))
        #print('IChar: ' + str(IChar))
      IChar = IChar * 2
      R = R * 2
      #print('R: ' + str(R))
      if int((IChar & H100) / 256.0) == 1:
        R = R + 1
      if (R & H1000) > 0:
        R = R ^ D
    R = R & HFFFF
    CheckICP = ("000" + format(R,'x'))[-3:]
    ICP_GEN_CRC = CheckICP.upper()
    # below ICP_GEN_CRC should be put in an attribute that i can use in an XML-creator.
    print('ICP_GEN_CRC: ' + str(ICP_GEN_CRC))
  return ICP_GEN_CRC
i expose ICP_GEN_CRC as output attribute , but it returns empty.
itsmatt
Forum|alt.badge.img+48
  • Nov 2, 2020 8:51 AM UTC
Hmm, Perhaps you want to use a Python Scripted Parameter instead? https://community.safe.com/s/article/python-scripted-parameters
Otherwise be sure you are creating FMEFeatures and setting the attribute value on a feature (http://docs.safe.com/fme/html/fmepython/api/fmeobjects/_feature/fmeobjects.FMEFeature.html).
  • Nov 2, 2020 9:48 AM UTC
If this is from a PythonCreator, then you're missing the part where you create the FME Feature and set the attribute 'ICP_GEN_CRC' accordingly. Simply doing this is not enough:
return ICP_GEN_CRC
Is this the entire code, of have you skipped some of it?
