Can we establish web connections for both transformers in one FME form- Sharepoint Online Connector and Sharepoint List Reader ?
  • Oct 18, 2023 5:14 PM UTC
  • 90 views
jaygrg111_
Forum|alt.badge.img+9
Since they use different parameter settings, can we have both of them established in the same FME Form? I am having issues while trying to establish the connections.
evieatsafe
Forum|alt.badge.img+28
  • Oct 24, 2023 6:45 PM UTC
Hi @jaygrg111_​ thanks for your question, I believe you should be able to! Perhaps I need more details, but all of your web connections can be found under Tools > FME Options > Web Connections and you can set up separate connections for each if you wanted to. If you could share with us what you have tried so far, we could give a more in depth answer. See our tutorials regarding SharePoint connectors for more information:
jaygrg111_
  • Oct 26, 2023 10:04 PM UTC
Hi @Evie Lapalme​  Thank you for your response. I was able to establish the Multitenant web connection on my Desktop outlined in this link (https://community.safe.com/s/article/How-to-Create-a-SharePoint-Web-Connection-for-FME-Form-Multitenant#SharePointOnlineConnector). But I am getting the following error on FME Server:- "Test Failed: Authorization and token retrieval was successful by refreshing the token using 'Refresh Token Parameters' failed. Requested to update access token failed. HTTP Error: HTTP/1.1 401 Unauthorized".
The Sharepoint admin has already given me the consent - but still I am getting the above. Let me know if know if I can explain it better in any way. Any suggestions/help is highly appreciated. Thank you so much.
evieatsafe
  • Oct 27, 2023 8:41 PM UTC
Ah perhaps this article should help: https://community.safe.com/s/article/Troubleshooting-SharePoint-Web-Connections-and-Services#unauthorized
Otherwise, @jaygrg111_​  I would suggest creating a case with us so that a support specialist can help you with this error!
