Can't get attributesplitter to work (text to colusms)
michiedem
Forum|alt.badge.img+7
My httpcaller results in a response body that is made up like a csv:
lat,long,time
a,b,c
a,b,c
a,b,c
I want the response body to be in seperate columns (lat, long etc..). I tried attributesplitter (both with , and carriage return as delimter)> listexploder > atributrenamer (attr_@Value(_element_index)). But I can not get it to work (it just makes a new column attr_@Value(_element_index)).
Best answer by caracadrian
michiedem wrote:
I can write it as a csv and read it again no problem. The problem is that I want the whole workbench to be one-click so I can schedule it without having to save a file in between. Besides this is not the first time I a running into this.
response_body
in text:
axis:latitude,axis:longitude,axis:time,data:Analysis_Data__sm_profile_analysis,data:Analysis_Data__sm_profile_analysis_ensstd,data:Analysis_Data__sm_rootzone_analysis,data:Analysis_Data__sm_rootzone_analysis_ensstd,data:Analysis_Data__sm_surface_analysis,data:Analysis_Data__sm_surface_analysis_ensstd,data:Analysis_Data__soil_temp_layer1_analysis,data:Analysis_Data__soil_temp_layer1_analysis_ensstd,data:Analysis_Data__surface_temp_analysis,data:Analysis_Data__surface_temp_analysis_ensstd,data:Forecast_Data__sm_profile_forecast,data:Forecast_Data__sm_rootzone_forecast,data:Forecast_Data__sm_surface_forecast,data:Forecast_Data__soil_temp_layer1_forecast,data:Forecast_Data__surface_temp_forecast,data:Forecast_Data__tb_h_forecast,data:Forecast_Data__tb_h_forecast_ensstd,data:Forecast_Data__tb_v_forecast,data:Forecast_Data__tb_v_forecast_ensstd,data:Observations_Data__tb_h_obs,data:Observations_Data__tb_h_obs_assim,data:Observations_Data__tb_h_obs_errstd,data:Observations_Data__tb_h_obs_time_sec,data:Observations_Data__tb_h_orbit_flag,data:Observations_Data__tb_h_resolution_flag,data:Observations_Data__tb_v_obs,data:Observations_Data__tb_v_obs_assim,data:Observations_Data__tb_v_obs_errstd,data:Observations_Data__tb_v_obs_time_sec,data:Observations_Data__tb_v_orbit_flag,data:Observations_Data__tb_v_resolution_flag,data:cell_column,data:cell_row
44.15776824951172,-104.51763916015625,"2020-06-23T23:58:55",0.24140433967113495,0.012575740925967693,0.2483765035867691,0.013659168966114521,0.11551471799612045,0.019027482718229294,297.3000183105469,0.9555330872535706,301.1864929199219,1.1795356273651123,0.24209845066070557,0.2493024319410324,0.12898384034633636,296.8999328613281,300.8611145019531,268.3493347167969,2.2372829914093018,282.1311950683594,1.9039433002471924,267.874755859375,274.24310302734375,4.0,6.46231292632128E8,1.0,1.0,283.8533630371094,283.6559753417969,4.0,6.46231292632128E8,1.0,1.0,808.0,245.0
44.15776824951172,-104.42427825927734,"2020-06-23T23:58:55",0.1767496019601822,0.009095101617276669,0.1818283349275589,0.009850835427641869,0.07577502727508545,0.01385344285517931,295.8811950683594,0.7661308646202087,299.606689453125,0.9440891742706299,0.17715446650981903,0.1823684126138687,0.08244185894727707,295.6227111816406,299.3885498046875,268.3493347167969,2.2372829914093018,282.1311950683594,1.9039433002471924,267.874755859375,274.24310302734375,4.0,6.46231292632128E8,1.0,1.0,283.8533630371094,283.6559753417969,4.0,6.46231292632128E8,1.0,1.0,809.0,245.0
44.15776824951172,-104.33091735839844,"2020-06-23T23:58:55",0.17419791221618652,0.007666847202926874,0.17883171141147614,0.008307178504765034,0.06947547942399979,0.011904611252248287,294.858642578125,0.6876235008239746,298.53839111328125,0.9207746982574463,0.1745859533548355,0.17935095727443695,0.07568531483411789,294.6627197265625,298.3641052246094,268.3493347167969,2.2372829914093018,282.1311950683594,1.9039433002471924,267.874755859375,274.24310302734375,4.0,6.46231292632128E8,1.0,1.0,283.8533630371094,283.6559753417969,4.0,6.46231292632128E8,1.0,1.0,810.0,245.0
44.15776824951172,-104.23755645751953,"2020-06-23T23:58:55",0.17362123727798462,0.01054029818624258,0.15977726876735687,0.009112892672419548,0.08134635537862778,0.01926041953265667,293.8444519042969,0.675663948059082,297.242919921875,0.8660253882408142,0.17384956777095795,0.16012121737003326,0.08625710755586624,293.6593933105469,297.0748596191406,268.3493347167969,2.2372829914093018,282.1311950683594,1.9039433002471924,267.874755859375,274.24310302734375,4.0,6.46231292632128E8,1.0,1.0,283.8533630371094,283.6559753417969,4.0,6.46231292632128E8,1.0,1.0,811.0,245.0
By the method I described you can have a "one click" workspace.
By using the TempPathnameCreator in front of the HttpCaller, and setting HttpCallet to Save Response Body to File, Create a New File Per Feature -> Yes, Output Folder -> _pathname (attribute from the TempPathnameCreator), seting FeatureReader to Dataset -> _response_file_path (attribute from HttpCaller), <Generic>Port -> axis:latitude / axis:longitude /... you can get the features directly with the attributes you desire
nielsgerrits
Forum|alt.badge.img+54
You just can use an AttributeCreator and select the list element, like _list{0},_list{1},_list{2}.
AttributeCreator Parameters
The biggest tip is to add an Inspector after your last step zo you can see where to look for. Just select a feature and check the Feature Information window.
InspectorDetail
michiedem
  • August 6, 2020
InspectorDetail
listSomehow that does not work for me, I get:
newattr1 newatrr2
lat , long, time a,b,c
That is when I use carriage return as delimeter. When I use , as delimeter I get a unique list() for every single value so that doesn't work either
caracadrian
Forum|alt.badge.img+23
  • August 6, 2020
Please provide a sample of your actual response body. I believe it's a multiline attribute.
Try writing the response to a csv file and use the FeatureReader to get your data back in the workspace. If your data has a header you can use the attribute names in that header as Attributes to Expose on the <Generic> Port in your FeatureReader.
You can add a TempPathnameCreator in front of the HttpCaller so the csv file get's deleted upon completion.
michiedem
  • August 6, 2020
response_body
in text:
Forum|alt.badge.img+50
response_body
in text:
If you use a FeatureWriter / FeatureReader combo it'll still be a single workspace. Granted it's not the most elegant solution but I agree with @caracadrian​ that it's probably the only option for now.
If you can share that response body as text rather than a screenshot we may be able to find another way to work around this. AttributeSplitter using carriage return first and then a second time using the , comes to mind.
caracadrian
  • August 6, 2020
response_body
in text:
michiedem
  • August 6, 2020
response_body
in text:
This is the response body:
michiedem
  • August 6, 2020
response_body
in text:
Thank you! But I am still amazed that I would have to take those steps.
response_body
in text:
The fact the HTTP response is CSV is making it more difficult in this case, XML or JSON would make it a lot easier.
If the request is a simple URL you may be able to just paste that URL in the source file box of a CSV reader (if there's authentication and stuff being done it probably won't work, unless you can add a token to the URL). That would also avoid the attribute splitting alltogether.
michiedem
  • August 6, 2020
response_body
in text:
It is not a simple URL linky besides: It contains dates and I want to automaticaslly modify those dates using the datetimestamper and I think the input url for the csvreader is static?
caracadrian
  • August 6, 2020
If it's not a simple url, you can create it in the FeatureReader, than expose what attributes you need.
gio
Forum|alt.badge.img+15
  • August 6, 2020
dynaWrite_Read@michiedem​
Using your csv sample. (which i copied and pasted in an attribute in the creator)
(one of the possibe solutions)
1 attributesplitter: name lof list "text_line_data"
2 listexploder
3 write using a Featureriter to a txt file. Name the file YourName.csv.
4 A featureReader (on the summary output port of the feaurewriter) and read the csv file wit comma seperator. U can enter the name u used inthe FeatureWriter, even if the file does not exist yet)
First time u run it, all attributes are of course hidden. U can see them in the FeatureInformationWIndow)
5 If u click again in the FeatureReader parameters after 1st run, the attributes become non hidden. (so it is not one click because of dynamically created attributes)
mark2atsafe
Forum|alt.badge.img+45
  • August 6, 2020
newattr1 newatrr2
So, I've tried it with some success (the method is below) but it might not be working because of hidden characters in the data.
So I would look at the response attribute in the FME inspector (or Visual Preview) by double-clicking the value to open it in a text window. That should have an option at the bottom to check for hidden characters:
inspectAttrCharts
If the result reveals no hidden characters, then the following should work, starting with:
lat,long,time
a,b,c
a,b,c
a,b,c
...then an AttributeSplitter (split on carriage return) would give you:
list{0} = lat,long,time
list{1} = a,b,c
list{2} = a,b,c
list{3} = a,b,c
Then a ListExploder gives you four features:
Feature 1list = lat,long,time
Feature 2list = a,b,c
Feature 3list = a,b,c
Feature 4list = a,b,c
Another AttributeSplitter (split on ,) gives you:
Feature 1list{0} = lat
list{1} = long
list{2} = time
Feature 2list{0} = a
list{1} = b
list{2} = c
Feature 3list{0} = a
list{1} = b
list{2} = c
Feature 4list{0} = a
list{1} = b
list{2} = c
And now you can use the AttributeCreator (or Renamer) to convert list{0} to lat, etc
If there are other parts to the response - as there seems to be - then you'd need to filter them out (probably a Tester after the ListExploder).
As others have said, there are XML and JSON transformers because we expect that format of data to appear mid-translation. CSV not so much. So writing/re-reading a file - as odd as it sounds - is probably the best method.
gio
  • August 7, 2020
@michiedem​
Here is picture of output.
dynaWrite_Read_output
gio
  • August 7, 2020
@michiedem​
michiedem
  • August 17, 2020
gio wrote:
@michiedem​
Hello gio: Thank you! after all the responses including yours i got it to work using the featurereader.
