Can I send a 'summary' email at the end of each run?
  • Nov 15, 2021 11:59 AM UTC
  • 83 views
benvk
Forum|alt.badge.img+8
I have a basic project as shown in the screenshot. In this example there are 54 items that need data cleansing (at the rejected port), I am wanting to send ONE email at the conclusion of this run, with a list of all the Property Numbers that were captured here.
If I add an emailer at this 'rejected' port I will get 54 emails. I am assuming there is a simple way to list then expand into the body of a single email?
workbench example
Best answer by david_r
You can e.g. use an Aggregator transformer to only send a single mail from the Rejected port. You could configure it to concatenate all the ID's into a single string.
  • Nov 15, 2021 12:03 PM UTC
benvk
  • Nov 15, 2021 12:20 PM UTC
Thanks David.
How do you recommend I format them into the HTML email?
Use <br> as the separator or similar?
  • Nov 15, 2021 1:02 PM UTC
Thanks David.
Depends on your requirements. Using <br> or a bullet list is certainly the easiest. If you want to get really fancy with it, you could use the HTMLReportGenerator.
