Can FME read a file on a UNIX server file directory?
  • May 6, 2023 1:28 AM UTC
  • 89 views
thomastupuivao
Forum|alt.badge.img+7
I have a text file that is created in an Oracle database and output to a folder on a UNIX server file directory. Can a FME workspace read a text file from this type of location?
  • May 7, 2023 6:16 PM UTC
I would say that it depends on a lot of factors that have little to do with FME. But if you can access the unix server directory from the server where FME is running (Windows, Mac or Linux), then it should work.
thomastupuivao
Thanks for that. Yes the unix server is the same location that FME is running on (Windows Server 2008). Is there parameters in FME that I need to configure?
  • May 8, 2023 12:20 PM UTC
I assume that you'll access the Unix share over a UNC path. The Unix share is something that your Unix admin needs to configure and to give you the corresponding UNC path. On FME you simply need to configure the service account and make sure it has permissions to access the Unix share. See also http://docs.safe.com/fme/html/FME_Server_Documentation/AdminGuide/Running_FME_Server_Engines_Under_Different_Account.htm
