Calculating total second from hh:mm:ss field
  • Nov 6, 2023 12:30 PM UTC
  • 138 views
Hello - I have several fields in hh:mm:ss format and I want to sum the total number of seconds from all parts all the field.
For example:
01: 10: 30
would total 4230 seconds
Does anyone know the best way to achieve this?
I am brining the data in from an API and have used the JSONFragmenter to tabularise the data.
I assume the current data type for the fields is string as that's the default for FME?
Best answer by nielsgerrits
This can be done using an AttributeCreator:
@DateTimeDiff(@Value(time),000000,seconds)
nielsgerrits
Forum|alt.badge.img+67
Thank you so much! :)
