Calculate value base on another field with published parameters
  • Aug 11, 2020 9:42 AM UTC
  • 6 replies
  • 83 views
jseigneuret
I have a problem to calculate value when use field name has a published parametes. All values are <missing>
This is my parameterNouvelle image bitmap
I check i with AttributeManager and attributeCreator and I have same result.
I have set Attribute value with that :
@Value($(Table_A_AttributeName))
Sans titre2
Forum|alt.badge.img+54
  • Aug 11, 2020 9:55 AM UTC
If you have the Attribute Assignment set to Default, you can just use $(Table_A_AttributeName) in your AttributeCreator.
If you want to reference it as in your example, you need to turn Attribute Assignment off
jseigneuret
  • Aug 11, 2020 10:14 AM UTC
no because If I do that I get only the field name in all features value.
I change the "Type" of parameter to "Attribute Name" and it works fine.
  • Aug 11, 2020 10:23 AM UTC
Do you see this little arrow when you type the attribute name?
Capture
If you have a parameter type of Text and Attribute Assignment set to Default and type in an attribute that exists, if you see this arrow in front of the name, you can reference it by using $(Table_A_AttributeName). Otherwise you reference using @Value($(Table_A_AttributeName))
Of course, changing the parameter type might be more appropriate for the situation too
jseigneuret
  • Aug 11, 2020 10:37 AM UTC
Capture
yes only if type is Attribute Name. With text type, this arrow doesn't exist. And if I set parameter with test has your exemple, FME can't find her cubs
  • Aug 11, 2020 10:40 AM UTC
Capture
Interesting, even with type text FME picks up the attribute for me (if it exists of course). If i want to set the value to text only I have to enter the parameter via the text editor
jseigneuret
  • Aug 11, 2020 10:53 AM UTC
Capture
I do multiple test case and we need clear data beween two change type because the parameter type is in memory.
I use FME 2020.1 (32Bit) - Because my Microsoft office is in 32bit and I can't use Access in 64bit when it exists a part of Office in 32bit
I prepare an fmw with different case to see the result
