CAD translation fails with Error Codes
  • May 2, 2018 9:12 PM UTC
  • 80 views
Hello all,
I'm converting CAD data and I'm receiving this error code:
Postcondition failed at topology.cpp:1089. Expression: remainingLRP != nullptr
I'm thinking that it is caused by bad CAD data. Has anyone seen this error before?
Also, I'm just looking at Walls (for the moment), but when I translate the data, doors from the door layer come through. Does anyone know what may be causing this?
Thanks, David
andreaatsafe
Forum|alt.badge.img+17
Hi @david_prosack88 ,
Sorry to hear you are receiving this error code. It is not a super informative error. Would you be able to share your workspace, log file and/or data? This will be helpful in trying to help figure out the error.
If you cannot share your data here, please submit a problem report here.
Thank you!
verdoodtdries
Forum|alt.badge.img+23
At which point during the translation does this error message pops up? While at writing, try to use a GeometryValidator to filter and correct the data before writing them to (another?) format.
Hi @verdoodtdries,
I re-ran the the workbench and added just walls to the workbench and received an "Error running translation" with it failing at the dissolver transformer. I also received multiple warnings before it failed saying, "a point was encountered that was enclosed in more than one polygon." I do not see any points in the CAD the drawing.
Thanks!
David
verdoodtdries
Hi @verdoodtdries,
Thanks!
David
Hi david_prosack88 ,
Can you provide a template workspace of the issue you want to solve. The points in FME are not automatically autocad_points. If you are e.g. using autocad_blocks these autocad entities can be read as points in FME. It all depends on your reader settings. I think your error message is due to the facts that you're providing input in the Dissolver transformer that can't be dissolved.
