Building facade(front) direction find out
  • Feb 3, 2023 10:37 AM UTC
  • 12 replies
  • 158 views
abii
Forum|alt.badge.img+4
Hi pls help me with this. I just want to know which direction building is facing. I have thousands of building and i want that at once all buildings front direction should come out. The data i have are building foot print(.shp), 3d model (citygml) and road center line(.shp)
JennaKAtSafe
Forum|alt.badge.img+9
Hi @Abinash Rout​, In your CityGML are you able to extract the <!--front surface--> tag? This isn't an area I'm an expert in but wondering if that would help. This documentation would be a good place to start as well.
abii
  • Feb 6, 2023 6:59 AM UTC
Thanks for replying but i just want to know if there is any transformer which will help me find direction like weather its facing south, north or south east etc.
abii
  • Feb 6, 2023 7:00 AM UTC
@david_r​ can you pls help me with this its really urgent
caracadrian
Forum|alt.badge.img+23
  • Feb 6, 2023 8:42 AM UTC
Use BoundingBoxReplacer set to 2D Oriented Bunding Box and give a name to the angle attribute.BoundingBoxReplacerThis will give you the direction of the longest side of the building, not the orientation of a specific facade.
Another method would be to use NeighborFinder with buildings as Base and roads as Candidates and use the _angle attribute to mao orientation.
abii
  • Feb 6, 2023 9:07 AM UTC
@caracadrian​ thank you so much.So from angle how will i identify the direction east, west or north-east etc.
  • Feb 6, 2023 9:27 AM UTC
Sorry, this is outside my area of expertise.
abii
  • Feb 6, 2023 9:31 AM UTC
okay thanks for reply
abii
  • Feb 6, 2023 10:28 AM UTC
@caracadrian​ pls explain the second method you suggested
caracadrian
  • Feb 6, 2023 10:42 AM UTC
Just input building footprints and road lines into NeighborFinder and use AttributeRangeMapper or AttributeManager to set geographic direction from angle value. I believe the angle is measured counterclockwise starting from the X axis - 45-135 degrees should mean north. Reading the Help helps NeighborFinder (safe.com)
abii
  • Feb 6, 2023 11:29 AM UTC
okay going to try it
thanks
abii
  • Feb 14, 2023 8:50 AM UTC
@caracadrian​  Thank you so much forgot to thank you 😅 . achieved what i was looking for
caracadrian
  • Feb 14, 2023 10:24 AM UTC
Glad you found a solution. Happy to help!
