Buffer certain sides of a polygon
  • Sep 15, 2021 12:56 PM UTC
  • 8 replies
  • 327 views
jugoslaviaa
I would like to buffer certain sides of a polygon. My polygon as in the image below and I would like to buffer them in the direction of arrows.
How can I do it with FME?
 5rZZvlhZGb
itsmatt
Forum|alt.badge.img+48
  • Sep 15, 2021 2:16 PM UTC
That's an Interesting problem - do you know the vectors/directions of these arrows?
how do you pick which side not to buffer?
Off the top of my head you could offset the original polygon in each direction (with an Offsetter) to get a total of four polygons (3 offset polygons and the the original). Then you could dissolve them with a Dissolver to get one polygon. This method requires you to know the directions of the arrows.
f.kemminje
Forum|alt.badge.img+11
  • Sep 15, 2021 2:28 PM UTC
do the arrow and text overlapped with polygon segments?
jugoslaviaa
  • Sep 15, 2021 3:10 PM UTC
I dont know the direction of the arrows
jugoslaviaa
  • Sep 15, 2021 3:11 PM UTC
I have only the polygon without an arrow and the text I have made it so that it is more understandable what my problem is.
caracadrian
Forum|alt.badge.img+23
  • Sep 16, 2021 4:54 AM UTC
Is there any criteria that the sides have to meet to be buffered? The orientation or length of lines? Maybe they have to be facing something or eliminate the side that is not?
  • May 1, 2023 1:01 AM UTC
Hi I have a similar challenge - I have polygons of trees and want to create buffers on the windward side (western in this case). Is there a way to do this with a FME bufferer?
DanAtSafe
  • May 1, 2023 11:19 PM UTC
Hi @dseverino​ Your first problem is to determine how the west side is defined. Maybe you could reduce the polygon to points with a Chopper and then offset (Offsetter) the entire feature by a negative value for x? Use a HullAccumulator to get the new shape or to find which points from the East side were moved are now in the interior of the new polygon?
  • May 2, 2023 4:10 AM UTC
Thanks, I'll give it a shot!
