Automatic populate <CreateTime> in the XMLTemplater transformer
  • Nov 21, 2023 11:46 AM UTC
  • 83 views
galigis
Forum|alt.badge.img+22
Hi All,
I have put a workbench together to populate some GIS metadata but I need to have the <CreateTime> automatically populate every time I run the workbench, below an example of the XMLTemplater transformer settings:
FME_3Currently the time if fixed as 00:00:000, How can I set it as variable parameter ? I have tried the ROOT Template Functions but didn't work.
Any advise more than welcome :)
Thanks
takashi.home
Forum|alt.badge.img+4
  • Nov 21, 2023 12:50 PM UTC
Hi @galigis​ ,
You can use Date/Time functions in an XML Template expression to get the current time and convert it to a preferable format. e.g.
<root>
    <CreateTime>@DateTimeFormat(@Left(@DateTimeNow(),14),%H:%M:%S)</CreateTime>
</root>
galigis
  • Nov 21, 2023 3:45 PM UTC
Bravo! Sorted, thanks :)
