Auth error with Reader/Writer to Portal but Web Connection test succeeds
  • May 11, 2021 4:39 PM UTC
  • 273 views
mattwilkie
Forum|alt.badge.img+11
Whenever we try to use a Reader or Writer to connect to ArcGIS Portal we're getting the error "Type 3, Number 1, Message: Failed to get authorization header" when using the [...] file browser button in the Service Parameters dialog.
(Workbench >> Add Reader >> Esri ArcGIS Portal Feature Service >> {add portal url} >> Parameters >> {select auth type: Web Service} >> {select portal web connection} >> [...] file browser >> >>> ERROR)
portal-error-type3-auth-headerWe've verified the portal Web Connection works (Tools >> FME Options >> Web Connections >> Manage Services >> {select portal connection} >> Test).
portal-connect-test-success
How to troubleshoot this further?
FME Workbench v2020.2. I'm not sure of the ArcGIS Portal version. I think 10.8.1.
mattwilkie
  • May 11, 2021 4:53 PM UTC
For Writer: if I change the Authentication Type from Web Service to 'Generate Token', fill in the appropriate credentials, the [...] file browser works, in that no error is emitted, however the following dialog is blank, no feature services are listed.
For Reader: if I change the Authentication Type from Web Service to 'Generate Token', fill in the appropriate credentials, then the [...] file browser works, and I can select a feature service and table.
portal-writer-gen-token-emptyportal-reader-gen-token-success
candacel
  • Nov 24, 2022 11:22 PM UTC
I'm trying to connect to portal with the writer and getting this same situation. Did you ever work it out? I can use webservice connection to read, but using write generates same Type 3 error message. thank you in advance
mattwilkie
  • Dec 1, 2022 9:06 PM UTC
Sorry nothing new to report. I haven't come back to this particular project in awhile.
