ArcPro maximum and minimum supported versions?
  • Mar 9, 2023 4:49 PM UTC
  • 5 replies
  • 694 views
louielou1234
Forum|alt.badge.img+5
Hi There,
After a recent upgrade of ArcPro (to v 3.1.0) I am now seeing this notation in FME Desktop and FME Server logs....Current installed ArcGISPro version '3.1.0' is unsupported. Minimum supported version is '2.3.0', and maximum supported version is '3.0.0'....what does this mean exactly?...do I need to upgrade FME?...on Desktop it doesnt seem to make a difference (I can still successfully run operations), but now some Scheduled Services are failing in FME Server and I am wondering if this is the reason. Thank you
Best answer by nielsgerrits
ArcGIS Pro 3.1.0 needs FME 2022.2.4. as can be read in Notes on FME and Esri Versions and Compatibility. Always check before upgrading as this may break the compatibility as you experienced. Especially as ArcGIS Pro is not backwards compatible as far as I know.
In ArcGIS Pro, under settings --> about, you can disable the checkbox "Check for updates on startup" to prevent the notification to show every time a new version is available. I did this because I can't keep up with the ArcGIS Pro update cycle speed in the production environment.
Forum|alt.badge.img+63
What version of FME do you currently have?
nielsgerrits
Forum|alt.badge.img+67
  • Mar 10, 2023 7:56 AM UTC
louielou1234
  • Mar 10, 2023 3:04 PM UTC
Hi...it is: FME Server 2022.1.2 Build 22627 - win64
louielou1234
  • Mar 10, 2023 3:05 PM UTC
That is a good tip, thank you
ron.florence
Forum|alt.badge.img+3
Is anyone successfully running ArcPro 3.1.2 (or 3.1.3/4) with FME 2022.2.1 ? We would prefer not to update to FME 2022.2.4 and we won't be upgrading to FME 2023 yet.
Thanks!
