ArcObject Error with FME 2020 / Migrated from FME 2018 version
  • Jun 16, 2023 8:32 AM UTC
  • 203 views
galigis
Forum|alt.badge.img+22
Hi Community,
I'm trying to run an existing FME 2018.0 workbench on FME 2020.2. and just received ArcObjects is: '-2147219879' error. Tried to search online but couldn't find the workaround/solution.
The FME workbench reads a GDB and applies metadata based on XML file as well as an excel file. Attached the log file for reference.
Any help more than welcome 🙂
kate-safe
Forum|alt.badge.img+11
  • Jun 16, 2023 3:27 PM UTC
Hi @galigis​ thank you for your post!
Typically when it comes to ArcObjects errors, we recommend searching the Esri database for the particular error as the error code being given is an Esri error.
I took the liberty of quickly looking up that error code in their table and found that the error is pointing to a "Field not nullable" error. I recommend taking a look at the data that you have, and ensuring that you have the right data types in place and that the attributes are correctly populated.
If there is anything further that we can help with please don't hesitate to reach out! ~Kate
