ArcGis Writer Error
  • Nov 8, 2022 4:17 PM UTC
  • 67 views
asadamjad
Participant
Forum|alt.badge.img+12
I am getting an error when I write to ArcGis Layer
I tried everything but still getting eroor
ArcGIS Portal Feature Service Writer: Encountered an unexpected error. The error code from the server was '' and the message was: 'Could not access any server machines. Please contact your system administrator.'. Details: ''
nampreetatsafe
Forum|alt.badge.img+14
We'll need some more information to help troubleshoot this error:
  1. What version of FME Desktop are you using?
  2. What version of ArcGIS Portal are you attempting to connecting to?
  3. Was this working for you in the past? If so, which versions of Portal and FME were you using then?
  4. Are you trying to connect to a hosted feature service? If yes, is the table hosted on Data Store or ArcSDE?
  5. Can you run your workspace with "Log Debug" turned on and share the resulting log file? To turn on in FME Workbench, go to Tools > FME Options > Translation > Log Message Filter > Log Debug
