ARCGIS ONLINE - Login Issue
  • Dec 19, 2022 10:01 AM UTC
  • 24 views
abnan0001
Forum|alt.badge.img+10
Hi
I was trying to use ArcGISONLINE Connector transformer to connect my services available within this account and the admin account also..
I was trying to login , after providing the username and password , Fme is reverting back to login page again
May i know , what might be the error
stefanh
Forum|alt.badge.img+8
  • Dec 19, 2022 12:44 PM UTC
I just tried the connection and it seems to work fine.
Which FME version are you using?
Did you try editing the parameters under 'Tools | FME Options | Web Connections'?
abnan0001
  • Dec 19, 2022 12:53 PM UTC
yes , I tried and from that option also i face the same error.
Tried in both ways , No Success..
FME 2022.1.3 version
Detailed Error is that:
Method 1 :
  • Creator then added arcgisonline connector , Provided username and password , then again reverted to same page..
Method 2:
  • Through FME Option - web connection faced the same error
