Anyway to use parameters when reading file from Web connection (Amazon S3)?
  • Sep 14, 2023 4:59 PM UTC
  • 0 replies
  • 44 views
aegman
Forum|alt.badge.img+3
When using the "Select file from Web > Browse Amazon S3" option as the source for a reader, is there anyway to pass parameters in to the dialog?
Select file from Amazon S3 dialogI have some FME Flow/Server workspaces that are called with the bucket name and path as parameters, I'd like to be able to use those parameters instead of hard-coding the bucket and path.
Currently we use the S3Connector with parameters to download the files to local temp and then a FeatureReader to read them, but it would be nice to read them directly.
Thanks,
Andy
