Am am getting a "Login failed, please try again" error after FME Server 2019 installation. Any assistance you can provide will be appreciated.
  • Apr 4, 2019 11:48 AM UTC
  • 256 views
pmcpherson
Forum|alt.badge.img+11
After installing, un-installing, and re-installing FME Server 2019, I'm unable to login to the web interface using the default credentials. The error that is returned is, "Login failed, please try again."
pmcpherson
  • Apr 4, 2019 12:48 PM UTC
I uninstalled again, this time making sure all FME Server services were stopped first. Then I deleted all folders and subfolders that had previously been created. After re-installing again, all is good.
Hi @pmcpherson,
I'm glad you were able to solve this one quickly on your own. Just for reference if anyone else hits this problem please review this article: https://knowledge.safe.com/articles/79069/after-an-fme-server-upgrade-i-cannot-log-in.html.
If you cannot log in after performing an in place upgrade this is the most likely culprit and a good place to start your troubleshooting.
