Align label with a line above the Center of each line ?
  • December 17, 2022
  • 25 views
gogopotter90
Forum|alt.badge.img+13
hello ,
I would like to add ID of each line above the Center of line .
but in some cases that the lines are rotating or have curves .
is there method that I can align label probably and avoid overlap the label on lines ?.
 As info : I do not have license for a Map text labeller.
Thanks in advance .
FME 2021
gogopotter90
  • December 21, 2022
Hello ,
has anyone idea ?and I would like to know if it is possible to write more than attribute as label.
i mean , not only the ID of cable some other attributes and create space between them
tomfriedl
  • December 21, 2022
You can use the Labeller to create labels. Create a new attribute with the desired content. Avoid overlaps labels is a real problem.
gogopotter90
  • December 28, 2022
Thanks ,my problem Bcs of overlaps
