Aggregate table: Only keeping maximum values
  • Dec 9, 2020 10:39 AM UTC
  • 7 replies
  • 359 views
I have a point feature containing different entries per point (multiple measurements on different heights), and i want to aggregate my attribute table in a way that only one entry per X,Y-point exist.
The final entry should thereby only contain the maximum values of all measurements per points.
I tried using the Aggregator tool, however, I was unable to keep the maximum values, since the only implemented functions seem to be average and sum.
I think of using my own python script withih a PythonCaller, but it did not work either (I know it must work , but I am pretty new to both FME and Python and just did not succeed).
Any help much appreciated!
Best answer by ebygomm
My data is rather like this...
In which case, you should just be able to use a StatisticsCalculator, Group by whatever ID you have for each point, choose the Measurements you want to analyse and get the _max
CaptureYou'd end up with something like this from the Summary port
Capture
  • Dec 9, 2020 1:05 PM UTC
I am more experienced with R, and using R I would solve it as follows:
# define data frame with test data
df=data.frame(
  name1=c("a","a","b","b","b"),
  name2=c("a","a","a","b","b"),
  value1=c(1,3,6,-9,10),
  value2=c(2,3,6,9,1),
  value3=c(10,3,3,29,2),
  value4=c(-1,34,6,9,6),
  value5=c(1,3,6,91,2)
# concatenate columns (as i want to group the df by 2 different cols)
df$list=paste0(df$name1,df$name2)
# aggregate df
df.aggregated=aggregate(x=df[,-c(1,2)],by=list(df$list),FUN=max)[,-1]
# re-add data of the two columns that the df was grouped by
comblist=match(df.aggregated$list,df$list)
combsorted=df[comblist,]
df.aggregated$name1=combsorted$name1
df.aggregated$name2=combsorted$name2
However, I did not manage to get RCaller work in FME...
Forum|alt.badge.img+54
  • Dec 9, 2020 1:12 PM UTC
Can you confirm, you have some data that looks like thisCaptureand you're aiming to get to something like this?
Capture
  • Dec 9, 2020 1:23 PM UTC
Capture
  • Dec 9, 2020 1:34 PM UTC
Capture
  • Dec 9, 2020 3:39 PM UTC
df=data.frame(
# aggregate df
By specifying the R interpreter (see http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/rcaller.htm) and the installation of many R packages (see https://community.safe.com/s/question/0D54Q000080hcFESAY/rcaller-no-package-called-sqldf) I finally managed to get my R code working.
The code above worked and did exactly what I was looking for. I just had to adjust my input dataframe (instead of my test-df I defined df as my input data from the previous FME Transformer)
df=Passed
and define an output at the end of my code
fmeOutput<-df.aggregated
However, I lost my spatial references on the way and thus had to redefine this, which was no problem...
  • Dec 9, 2020 4:17 PM UTC
Perfect! That's exactly what I was looking for. However, is there a possibility to keep the other attributes (those of which I did not calculate any statistics)?
  • Dec 9, 2020 4:23 PM UTC
If the values are shared across the features, you can add them to the group by. If they vary across features, you need to decide how you will decide which value to keep. If you look at the data coming from the Complete port, that will contain the min and max as extra attributes against the original data.
