Advanced Feature Type Parameters of the wrtiter in FME server are different then the upladed workbench writer table genaral settings.
  • Feb 26, 2022 7:00 AM UTC
  • 55 views
dannymeus
Forum|alt.badge.img+15
When viewing (in FME server) my workbench that I uploaded tot FME server I see different Advanced Feature Type Parameters settings then in my Workbench on FME desktop.
In my workbench the settings of my writer are 'insert, drop and create' after I upload the same workbench to FME server the settings in server seems to be 'insert, create if needed'.
Why is that? I do not expect the settings change while uploading tot FME server.
If I run the workbench from server the outcome is that the writer used the 'Drop and Create' and not the 'create if neded'...this behavior is confusing
settings in my Workbench on desktop:
the settings in FME server of the same workbench after uploading to server:
  • Jul 31, 2023 2:14 PM UTC
I also have the same issue. WB is set to Yes for "Truncate First" and when I publish the WB to server the "Truncate First" is set to no.
