Adding a value start of the attribute
Hi FME Experts,
I would like to add a specific value (03) start of the attribute to make the attribute digits 4.
EX:
origin value new value
78 0378
5 0035
Thanks in advance!
  • July 5, 2019
You can concatenate character '3' and the original value then format it in four digits padded with zeros using the StringFormatter, as in:
  • July 5, 2019
Thanks, @takashi your answer helps me, but what about if I have the original value already 4 digits ( in this case I don't need to add the "03" at start of the attribute
  • July 5, 2019
You can use the StringLengthCalculator to get the number of characters and use the Tester to filter out the feature if the number was 4 (or more).
