Adding a pdf underlay to dwg-file?
  • Aug 13, 2021 2:24 PM UTC
  • 146 views
Is it possible to add a pdf as an underlay in a dwg file with FME?
I am setting up an automated process for creating dwg-files. Im adding vectordata from a database but i would also like to include a pdf created with arcpy in my dwg. I can see from the format docs that there are attributes for xref:s but i can't figure out how to do it.
I have the necessary coordinate information to place my pdf correctly, just not a way of adding it.
If it's not possible to create xref:s with FME, is it possible to simply update the xref information in a template dwg-file (including position)?
daveatsafe
Forum|alt.badge.img+24
  • Aug 18, 2021 10:44 PM UTC
Hi @stormare​,
I'm sorry, but FME does not presently read PDF Xrefs in a DWG file. I have created an enhancement request (FMEENGINE-70470) to add this functionality, and will notify you as soon this is complete.
andreaatsafe
Forum|alt.badge.img+17
Hi @stormare​ ,
I'm pleased to let you know that FME 2021.1+ now has added support for reading PDF xrefs in DWG files.
This functionality can be found in the latest beta: safe.com/beta
-Andrea
  • Jul 6, 2022 6:37 AM UTC
Hi @andreaatsafe​!
Thanks for the update. I'm looking forward to testing this feature. If it works the way i hope it will significantly improve our product!
