Add a map image to an email without google map api key
bilal
Forum|alt.badge.img+4
How can I add a map image to an email.
I have a lat long coordinate. I do not have a google maps api key so google maps is out of the question. Any tips would be really appreciated.
Best answer by hansgm
Hello
You can use a Imagefetcher Transformer
You can get a static map with the following Image URL:
http://osm-static-maps.herokuapp.com/?height=600&width=600&center=2.29469,48.8583&zoom=20&attribution=© OpenStreetMap-Contributors
Options for the URL can be find here
https://github.com/jperelli/osm-static-maps
More static maps are documented here
https://wiki.openstreetmap.org/wiki/Static_map_images
Forum|alt.badge.img+50
Do you need global coverage? If so, I think there's some OpenStreetMap WMS services you could use to get static images from and embed those.
hansgm
  • August 18, 2020
Hello
