Add a basemap transparency setting
  • May 14, 2026 10:53 AM UTC
  • 61 views
p_c_20
Forum|alt.badge.img+9
Basemapping available to our org is limited. Several are dark or the level of colour obfuscates point geoms in particular. Can we have a basemapping transparency/colour intensity setting?
j.botterill
Forum|alt.badge.img+69
  • May 19, 2026 10:33 AM UTC
You can do this already in Visual Preview/Data Inspector. Find the Data Display tab, click on the cross hair icon of each layer to find
  1. Under Symbology, you can adjust:
    • Opacity / Transparency
    • Colour (fill and outline)
    • Line width
    • Point size
    • Label settings
Changing opacity is especially useful when:
  • Overlaying multiple datasets
  • Comparing source vs processed data
  • Visualising dense polygon layers
p_c_20
  • May 19, 2026 10:37 AM UTC
    • Line width
    • Point size
    • Label settings
Excellent, thank you
