1st Data transfer to data
  • Nov 1, 2022 6:47 AM UTC
  • 6 replies
  • 77 views
asadamjad
Participant
Forum|alt.badge.img+12
what I trying to do is write the values in the Database and then read from there as a reader
but the problem is when I run my workspace its runs same time
what I m want is 1st load the data and then reader-run
f.kemminje
Forum|alt.badge.img+11
  • Nov 1, 2022 6:56 AM UTC
Use the feature writer transformer to write DB. and then take the output from there and read the table using the feature reader
asadamjad
Participant
  • Participant
  • Nov 1, 2022 7:00 AM UTC
if i used that then it will read 1st then writer correct ?
asadamjad
Participant
  • Participant
  • Nov 1, 2022 7:03 AM UTC
its taking to much time to read and have only one column and 1 value only imageimage
f.kemminje
  • Nov 1, 2022 10:54 AM UTC
use featurewriter transformer to write MD5
then from the same writer take the summery output and then use featurereader to read MD5
asadamjad
Participant
  • Participant
  • Nov 1, 2022 11:09 AM UTC
yea its taking time to read the data around 15 mins
danminneyatsaf
Forum|alt.badge.img+13
@asadamjad​ You've almost got your workspace in the right shape, so great job. There is one thing that you will need to adjust in your workflow. Instead of having the FeatureReader_3 connected to the Creator, you will want to connect it to the FeatureWriter which writes out the data in your to PostgreSQL. I've included a screenshot of how your workspace should look below.
If you're still having issues with reading the data, then please reply with a copy of your workspace logs attached.
Hope this helps!
