Reading labels, healing contours with AI. Part 2
  • May 5, 2026 4:52 AM UTC
  • 133 views
dmitribagh
Forum|alt.badge.img+20
Hi again,
I hope you don’t get an impression I am spamming the group, but I took my previous output a few steps further (thanks ​@janrykr) - after all, how can I measure that I actually achieved the desired goal - turning labels into something meaningful. So, I vectorized the isolines, overlaid labels over lines, forced lines to 3D with the elevations received from points, built a TIN, added the source raster as a texture, and used my 3DModelVideoRenderer to visualize the output, giving this post the necessary for this group AI-component - the Python code in the transformer is generated with AI. Considering that not all lines got elevations, I think the result is actually quite good.
Dmitri
oliver.morris
Forum|alt.badge.img+14
Hi again,
Dmitri
Please keep sharing your progress ​@dmitribagh, you are definately not spamming 😊
User15904968838663764003
Forum|alt.badge.img+8
Do you consider adding some of those as workspace templates on the hub ​@dmitribagh ?
dmitribagh
  • May 12, 2026 7:04 AM UTC
​@User15904968838663764003 This particular one works with real customer data, which is okay to show, but I can’t include it into the template. In general, I will try to add a few of my recent AI examples in one of the future webinars.
Dmitri
