WorkflowManagerJobCreator
  • Feb 14, 2024 6:00 PM UTC
  • 0 replies
  • 40 views
fmelizard
Forum|alt.badge.img+22
FME Hub user sashal just uploaded a new transformer to the FME Hub.
Create a Workflow Manager Job
This transformer creates a job in ArcGIS Workflow Manager. The custom transformer uses the httpCaller transformer to make a REST API call to the ArcGIS Workflow Manager REST API and outputs the job id of the job created. All attributes needed to populated the REST call are parameterized.
Dependencies to using this transformer:
ArcGIS Enterprise with ArcGIS Workflow Manager Server (version 10.9.1 or 11.x)
Web Connection to ArcGIS Enterprise (how to establish FME Web Connetion to ArcGIS Enterprise Portal)
User with web connection must have privileges to update Workflow Item
Existing Workflow Item & Job Template in Workflow Manager
Would you like to know more? Click here to find out more details!
