TurkishNationalTopographicGridSystem
  • Sep 24, 2024 3:00 PM UTC
  • 0 replies
  • 36 views
fmelizard
Forum|alt.badge.img+22
FME Hub user ardadurmus just uploaded a new transformer to the FME Hub.
Turkish National Topographic Grid System Transformer
This custom transformer generates national topographic map sheets for Turkey based on a given point or area. It uses the official Turkish national grid system to identify and create map sheets corresponding to the input location.
Input: Point(s) Line(s) or Area(s)(polygon) within Turkey
Output: National topographic map sheet(s) based on the national topographic grid system in various scales.
Available Scales:
1/100,000
1/50,000
1/25,000
1/10,000
1/5,000
1/2,000
1/1,000
1/500
Key Features:
Works with both single points and larger areas
Automatically determines the correct map sheet for the location
Supports various scales for map sheet generation
Would you like to know more? Click here to find out more details!
